Custom Front Hitch Mount
17 Jan 2025 10:48 #18475 by Geno
Custom Front Hitch Mount was created by Geno
Well the Custom Made section got messed up in the move so I'm putting this here.  Something else I need to fix...
Anyway, I started on a custom receiver hitch that goes on a front Tach-A-Matic bracket a few days ago and am sharing what I did in case others would like to do the same.  I have a few bad brackets so I started with one of those.  This one had the the shank and threads for the pulleys missing as you will see in the pics.
First up was to get the broken rod out and remove the adjustment and ears for the belt tension.  Basically it was just gutting the bracket minus the upper rod.  After that a 3/16" steel stop was welded in toward the bottom so it would stay straight on the tractor.  I used a Tach-A-Matic from a used parts pallet of them for the fitting of everything.  I keep what a lot of peeps would normally throw away just for these kinds of things. They come in handy for things like this and avoid cutting up good used parts.  Also, when peeps see what I make a lot of times they want me to make one for them too.  The pic of it on the tractor is just a test fit after tack welding before the stop was completely welded in.
21 Jan 2025 15:03 #18476 by Geno
Replied by Geno on topic Custom Front Hitch Mount
I had to order some drill bits for the receiver and hitch holes and they came in today so I started playing around with the hitch project again.
The holes are supposed to be 21/32".  The size is inbetween 5/8 and 11/16, perfect for the 5/8" pins.  I'll prob be making a lot of these so I got cobalt bits.  The 3 pack wasn't much more than a single so it made sense to have a few extra on hand.
22 Jan 2025 18:32 - 22 Jan 2025 18:33 #18478 by Geno
Working on a lot of projects today but managed to get the receiver and a few extras drilled, will be keeping one for a pattern.  The first 2 pics are of one of my Incra Rules that I use for precision marking like this so holes line up right.  There's not a lot of play here once you drill 4 holes in 2 pieces of steel, or drill just the receiver that has to line up with store bought pieces.
If you're interested in these you can search Amazon, they come in a lot of sizes and sets, the 18" set is here -  Incra Rule 18" 3 Piece Set
Everything was planned so that there's clearance in the bracket, if something is a little longer it can go a little deeper.  So far everything is perfect, a little prep and welding is next.
Last edit: 22 Jan 2025 18:33 by Geno.
23 Jan 2025 17:00 #18479 by Geno
All welded up.  I have another insane idea for this, working on it now...
24 Jan 2025 18:27 #18481 by Geno
The big holes got welded in where the cross shaft for the pulleys mount, it made it look a lot nicer.  I'm not sure I'm done with it yet so I left some other holes in it for now.  It also got G70 hooks welded on each side.  It looks like a little monstrosity now.
I had someone in yesterday that saw it wants one, I knew this would happen...
The last few pics are of a setup I'm making to put on my heavy trailer to winch things up on it.  I actually made the WH front hitch setup because I had everything out already to do the trailer setup.  I'll put a post up on it later in the Tools + Equipment section.
15 Feb 2025 17:23 #18491 by Geno
I finished up making a bunch of weld on receiver tubes today and decided to put a 3" ring on this setup.  No it doesn't need it but it does make it look even more like a little monster...
