Starting Fluid - 520H Onan
  • GoBucks
  • Junior Member
  • Junior Member
28 Jan 2019 15:12 #15164 by GoBucks
I just went out and tried it again. I think I did it right to begin with. That's just as closed as it gets without using my finger. I was able to start it ok with the choke slightly open though. Thanks
28 Jan 2019 16:21 - 28 Jan 2019 16:25 #15165 by Geno
GoBucks wrote: Should the choke close completely?
520H choke
Whatever that is above no one can see it without logging into Google and I have no idea what my login is it's been so long lol. If you have a pic on your computer just drag it into the post and the forum will take care of it automatically. :thumb
You should be able to close it completely, I wonder if the cable has enough throw to do it before it hits the sheath. A pic would be nice.
Last edit: 28 Jan 2019 16:25 by Geno.
  • GoBucks
  • Junior Member
  • Junior Member
28 Jan 2019 16:24 #15166 by GoBucks
Try this
28 Jan 2019 16:28 #15167 by Geno
It should close tight. I don't spend a lot of time near the puter and typing just don't get it done very fast. I could set it or find the problem in less than 30 seconds if it were here lol. This is why most people call me instead of asking for help on the forum I guess. :rolling
  • GoBucks
  • Junior Member
  • Junior Member
28 Jan 2019 16:31 #15168 by GoBucks
This makes no sense. I'll have it closed, then it won't close again. Annoying.
28 Jan 2019 16:35 #15169 by Geno
Just sent you an email, call me lol. :tounge2
  • GoBucks
  • Junior Member
  • Junior Member
01 Feb 2019 22:19 #15183 by GoBucks
I tried adjusting it several times on the phone with Geno today, this is the best I can do. Now I have an electrical issue, so I can test this to see if it's good enough.
Time to create page: 0.180 seconds
