Lift bar hitting the center spindle on 48" deck.
03 Jun 2015 12:17 #5237 by Kurt-NEPA
Replied by Kurt-NEPA on topic Lift bar hitting the center spindle on 48" deck.
Here is mine, That lift rod almost looks bent to me.
[IMG
03 Jun 2015 12:21 #5238 by Geno
Looks like the rod is bent to the right (looking at the pic). They could have welded it that way. Seems the easy thing to do here is bend the rod toward the left (looking at the pic). :)
03 Jun 2015 12:26 #5239 by Kurt-NEPA
That's what I'm thinking too. It will probably take two bends. I think I am off to get my empty oxygen tank filled.
Thanks,
03 Jun 2015 12:28 #5240 by M Bailey
Yep, the lift arm looks like it twisted to the left. The only reason it wasn't a problem with the 42RD was the fact that the spindle was in front of it. Looks like you've got it figured out Kurt! Save that old spindle shaft if you can and save yourself about $50.
03 Jun 2015 13:38 #5241 by Kurt-NEPA
Sure looks like a twist in the photo. I'll see what it looks like when I get it out. Might be a day or three.
I agree on the 42RD. I was looking at it and the spindle is further forward and the lifting frame sits higher above the deck. Lots more clearance.
I think I can weld up that spindle and re-drill the hole and tap. Nothing to loose but a little time.
Thanks
Kurt
03 Jun 2015 17:54 #5248 by Trouty56
This is a common problem discussed at length before....what some guys do...same as me.....is put a small bolt in there....some guys put a dab of silicone in the hole....put a zerk in to grease it and pull in out.....
03 Jun 2015 19:17 #5251 by Kurt-NEPA
Not a bad idea Bob, If my memory is any good, The thread is 1/4-28. If I just clean it up and re-tap than put a bolt in to protect things. Sounds like a plan.
Thanks
03 Jun 2015 21:19 #5258 by GT 14
Your on the right road Kurt, like you say just a little time, sweat, skinned knuckle... :hi5
08 Jun 2015 08:59 #5527 by Kurt-NEPA
Update, I'm making progress.
After thinking about a bent lift bar, I found a used one at Joe's for a reasonable price. It arrived Saturday. Strange that it is of a different design. I compared the two bars for a twist or bend and found this.
[IMG
So I found the source of the problem, That lift bar was bent. Here is the spindle clearance I have now.
[IMG
I pulled the spindle. I had no luck getting the old zerk out, so I turned down the end of the spindle about .100" and chased the threads. Worked perfectly.
After I remounted the deck and started it up, I now have a new problem. I am getting a high speed noise. Sounds something like an out-of-sync prop on a twin engine airplane. I pulled the deck and checked everything out. The spindles turn easily, no roughness. But I did feel a creaking in the belt. With my finger on the belt and rotating the spindle, I can felt something in the belt. Almost like a series of snaps as it goes over the pulley. Strange, the belt is an almost new (4 hrs) PIX belt. I think I'll try a new belt, maybe a Toro belt this time.
Thanks for all the help. I hope the pictures show up OK, the preview is not working (yet).
Kurt
08 Jun 2015 09:18 #5528 by Kurt-NEPA
Here is a picture of the chowdered spindle
[IMG
And the lift bars. Left is original (no wonder that was not working), center is the bent bar that caused my problems, and right one is the used part I got from Joe's
[IMG
Time to create page: 0.213 seconds
