Mower Deck ID (Plus the Whole story, very long)
08 Aug 2015 10:04 - 08 Aug 2015 10:05 #7620 by AJ WH Ranger
Replied by AJ WH Ranger on topic Mower Deck ID (Plus the Whole story, very long)
Well I'm going back out there to finish up the cleanup and rebuild..
Still trying to get those blades off.. What a bear! :waiting :angry2 :angry
Major do you know what bearings are used in the spindles? I have seen quite a few different numbers pop up when searching?
Last edit: 08 Aug 2015 10:05 by AJ WH Ranger.
09 Aug 2015 06:02 #7638 by M Bailey
AJ, when it comes to deck work an impact wrench is your best friend. all 3 of my 42" decks use 106085 - 106084 bearings, the 106085 being unsealed and the 106084 sealed. Don't order the bearings until you pull out the old ones to verify the size. Take a look at my reassembly guide Spindle Bearing Installation
10 Aug 2015 08:39 #7671 by AJ WH Ranger
M Bailey wrote: AJ, when it comes to deck work an impact wrench is your best friend. all 3 of my 42" decks use 106085 - 106084 bearings, the 106085 being unsealed and the 106084 sealed. Don't order the bearings until you pull out the old ones to verify the size. Take a look at my reassembly guide Spindle Bearing Installation
Exactly what I was looking for!!
Thank you.
We will have to get together for that governor on that Lawn Ranger..
Time to create page: 1.303 seconds
