Tiller guts
22 Mar 2015 12:03 #1568 by Trouty56
Kyblue wrote: They really are simple ... I'll need to put a chain in mine this winter.
I was told the same thing....however, on this tiller the seals were both the same way....not sure what is best....there was a space a little space between the seals....do you think grease would help between the seals??? Without lubrication I would think the outer seal would not last too long...
22 Mar 2015 12:33 - 22 Mar 2015 12:38 #1570 by Trouty56
GT 14 wrote: If you can get em for 12$ that is the way to go. Even buying left and right you may need the other in the future.
Here is an example of the D series tine...left side which I think is looking at the rear of the tiller....it curves to the left side....
www.tiller-blades.com/C-Blades/6275-TORO...pl.html?keyword=toro
15 bucks shipping though....that is almost 30 bucks a tine....
Last edit: 22 Mar 2015 12:38 by Trouty56.
22 Mar 2015 12:58 #1571 by Kyblue
I don't think using some grease would hurt a thing. Actually I think it's a great idea...and I'm sorry I didn't think of it when i did mine
22 Mar 2015 17:31 #1602 by GT 14
They say there hardened and coated. Maybe worth it.
22 Mar 2015 19:48 #1644 by Trouty56
Found another place.....
www.cleancutter.com/cat_alpha_frame.htm
23 Mar 2015 06:09 #1692 by GT 14
If I am reading it right hardened and coated would run about 18$
24 Mar 2015 13:22 - 24 Mar 2015 13:25 #1853 by Trouty56
So I ordered a tine from this outfit.....
Actually I ordered 3.....I need a left so I ordered an extra left and a right for spares.....so I got 3 plus shipping was less than 30 bucks.....I'll get some pics when they arrive....
I just got regular ones (20% discount no less).....I can face them here if I think they are needed.....I'll be plowing the ground over so I doubt I will need hardened tines.....
Last edit: 24 Mar 2015 13:25 by Trouty56.
24 Mar 2015 13:39 #1854 by GT 14
Trouty56 wrote: So I ordered a tine from this outfit.....
Thats a good deal! Are you still welding or using the bolt holes?
24 Mar 2015 14:15 - 24 Mar 2015 14:16 #1856 by Trouty56
I have to weld this one on.....there isn't a stub to bolt it to. It is broken at the shaft....take a little grinding and bracing but I think it will be fine.... You know a guy could make a shaft up with bolt on plates and have a set of these bolt on tines....would take 12 a side...then you would be set to go....
Last edit: 24 Mar 2015 14:16 by Trouty56.
24 Mar 2015 15:30 #1860 by GT 14
Trouty56 wrote: I have to weld this one on.....there isn't a stub to bolt it to. It is broken at the shaft....take a little grinding and bracing but I think it will be fine.... You know a guy could make a shaft up with bolt on plates and have a set of these bolt on tines....would take 12 a side...then you would be set to go....
Yea a little work up front could save in the long run. Is the D set-up that way?
