Home Made Portable Air Filter
He runs an HVAC business and got an old gas furnace they just took out of a house and modified it. He made an inlet filter box on the return that holds up to 4 20 x 20 filters and he also put one on the output side. The output elbows can be put in any direction to put the air where you want it. He brought me 36 filters to get started and see how long they last. It will also make a great fan when it gets warmer out. It should help a whole lot with the messes I make around here. Going to try it out here in a little bit if it stays quiet around here.
There's a 3 speed fan switch coming for it this Wed so the speeds can be adjusted on the fly, then it just needs to be painted red lol.
The filter system is good, I had all 5 filters in it for the test run and the one pulled out in the pic is the last of 4 closest to the blower. There's also hardly no paint floating around in the shop like a haze even with everything closed up completely while I painted. It is also making the paint dry a lot quicker just from all of the air movement. I like it for sure but need to experiment with it a little more. :smile2
Does the wiring look ok Kev? It's color coded and everything lol.
- Kevinwb9
- Member
