Home Made Custom Movers Dollies
25 Nov 2022 09:23 #17845 by Geno
Home Made Custom Movers Dollies was created by Geno
With the price of movers dollies going up and up, and needing more of them and wheels in general I found a good deal I thought I would share. My order is arriving today. My plan is to make a lot of custom dollies out of scrap lumber sitting all over the place. They should be around $5 each (with 4 wheels) no matter the size. The wheels are also really cheap and can just be mounted directly to things as well. I doubt this type of polyurethane caster will ever be cheaper anywhere than they are right now. Get them before they go up like everything else... :tounge2
They have a lot of great ratings, are around $1 each shipped if you have Amazon Prime and are here - 50 Pack Castor swivel wheels
Here are the specs -
50 Pack Caster Swivel Plate On Blue Polyurethane Wheels (2" no brake)
PLATE SIZE: 50mm, 1.96" X 50mm, 1.96". Hole Center To Hole Center: 33mm, 1.29". 2 inch Caster Wheels No Brake.
360-DEGREE MANEUVERABILITY: These polyurethane caster wheels equipped with 360 degrees swivel bracket, the wheels can turn to any directions. Smooth and Silent and Sturdy. Capacity: 65lbs each wheel. Move the light furniture, table, cabinet and equipment to the destination more easily and flexibly.
MOUNTING HOLE DIMENSIONS: 6mm X 11.7mm. Caster Wheel Width: 19mm, 0.7". Overall Height: 70mm, 2.75". Caster Wheel Diameter: 50mm, 2".
WHEEL MATERIALS AND PERFORMANCE: Heavy duty casters made of polyurethane wheels. COLOR: Blue. Ball bearings: Double ball bearings. Premium Caster wheels are made of high-quality polyurethane wheels with strong abrasion resistance, silent shock absorber, wear proof, no drag marks and enhance the impact resistance of the whole caster.
