New Grinder + Misc Bench Project
Most of the time was spent planning where the bolts would go through the top to mount everything without hitting anything crucial underneath, while also anchoring the top to both wood shelves under the metal. Hopefully tomorrow I can get the 4 pieces of equipment mounted on it and clean up some more of the mess around here. All of the Fastenal stuff is back out in the 4 car garage and some room is starting to appear in the shop again.
Most of the mounting was done yesterday and today with what I use on a lot of projects, grade 9 bolts of course. A little overkill never hurt anyone. These fixtures are a little over 4' each when assembled and the metal was a little short so I made an overhang on the drill press end for the outer trim, then made an end cap out of some 1 1/2" angle iron for the other end. It just bolted on through 2 of the top holes in the fixture posts. One of the little tricks I do is in a pic with the magic marker in it. When butting 2 pieces together just make a wide black strip under the 2 pieces being butted together and it will make it look perfect.
Next up was insulating the belt mill. It always had a little vibration through the bench so I cut a piece of the 3/8" rubber flooring, punched a few holes in it, then put it under it. That should make it nice and smooth. I also doubled up on the front to rear braces to make it more solid.
It's coming along pretty good. I finished up all of the mounting + outer trimming today and I think all that's left is figuring out where to put a hidden power strip, put the cords back together, then put some shelves on it and the bins in it.
I need to make time this Winter to redo some of the other equipment like the grinders, they are my fav Wheel Horse tools lol.
The red cart that was sitting the back storage room came in real handy too. All of the bigger hand tools fit in there without a problem. The other nice thing is now there's another tabletop with wheels, can't ever have enough of them...
