Raider 12 Refresh
28 Feb 2019 13:00 #15254 by Geno
Raider 12 Refresh was created by Geno
This one won't take long and won't make dust so it is next. No restore and not much painting here. I already have the correct decals for it, it needs some wiring fixed, the correct throttle set up installed, the RF wheel is wallowed out and no good, and a few other things.
1st pic is one he sent me before I bought it. The tires and weights may end up on dad's old 414 with a set of 520 rear wheels. I still use that tractor for everything here in the Spring, Summer and Fall except mowing and it would be nice to have them on there. :thumb1
28 Feb 2019 18:45 - 28 Feb 2019 18:46 #15256 by Geno
Replied by Geno on topic Raider 12 Refresh
Took a little longer than I thought, the rear tires were full of fluid. :doh
I finally have the rears off dried out and done and a correct front wheel set ready. :thumb1
Last edit: 28 Feb 2019 18:46 by Geno.
01 Mar 2019 13:03 #15259 by Geno
Just took the front tri ribs off of this thing and they are filled with fluid too. Somebody was serious about weight on this thing... :surprised
The rims going back on it got painted this morning.
02 Mar 2019 18:32 #15265 by Geno
Nick picked up his B100 this morning and after some shop cleaning and organizing I'm back here again. She is shining up pretty good. :yes
05 Mar 2019 14:13 #15266 by Geno
Well here come the might as wells... :rolling
The tower was broken at the bottom left so had to pull the step to fix it, might as well blast the step and put new treads on it. If you're doing the left might as well do the right, then there was a bracket broken on the right that holds the step and belt guard so the guard has to be pulled to fix that, might as well clean up the ugly bracket someone welded on and blast the belt guard... :laughing
06 Mar 2019 13:09 #15267 by Geno
Might as wells and tractor are all done. She looks pretty good to be 50 lol. :thumb1
