'Hub Cap' or 'Wheel Cover'
  • GlenPettit
  • Vendor-Supporter
  • Vendor-Supporter
22 Apr 2015 09:26 - 22 Apr 2015 09:32 #3632 by GlenPettit
'Hub Cap' or 'Wheel Cover' was created by GlenPettit
A Hub Cap is a small Rubber or metal cap that covers only the hub or exposed axel, usually 1–3" in diameter, also called a 'dust cap', usually a press fit that snaps on.
A Wheel Cover is larger and covers almost the entire metal wheel, usually a fancy Chromed metal (or often plastic today) and held on with 3-4 spring clips, and covers both the center hub & the lug nuts, leaving only the rubber tire exposed.
The Wheel is the rigid circular metal frame that the rubber Tire fits onto and around. The circular outside Rim is welded to the center hub-axle-lug nut assembly, these two pieces now become a Wheel.
Both names are often used wrong and inter-changed, even in printed advertising; these are the common dictionary definitions.
Because we do make the rubber Hub Caps for these Garden Tractors, 1.25, 1.5, 1.62 & 2"ID sizes, I'm very familiar with these terms and the confusion, argument, misuse they often get.
Last edit: 22 Apr 2015 09:32 by GlenPettit.
The following user(s) said Thank You: Geno, GT 14, M Bailey
22 Apr 2015 13:05 #3638 by Geno
Replied by Geno on topic 'Hub Cap' or 'Wheel Cover'
Thanks Glen. :thumb1
Time to create page: 0.092 seconds
