15 minute throttle lever fix
15 Mar 2016 19:20 #10856 by Geno
15 minute throttle lever fix was created by Geno
I should have put this up before but never did. Just got through doing the 520 we'll be mowing with this Summer so thought I would grab a pic.
Remove cable.
Drill rivet.
Insert bolt with lock washer and lock nut.
Use speed clips and screws to reassemble.
Job done and it is adjustable from now on. :)
The following user(s) said Thank You: jimmyman60
15 Mar 2016 21:20 #10857 by Kurt-NEPA
Replied by Kurt-NEPA on topic 15 minute throttle lever fix
I like the speed clip technique. I think I will steal it.
15 Mar 2016 22:41 #10858 by Geno
Replied by Geno on topic 15 minute throttle lever fix
Steal away lol. A lot easier than trying to get those dang nuts on. :rolling
04 Aug 2018 22:05 #14784 by jimmyman60
Replied by jimmyman60 on topic 15 minute throttle lever fix
I just did this on my 1988 416-8 this afternoon. I used a 1/4-20 bolt, flat washer and (2) 1/4-20 nuts (one was a jam nut with loctite because I didn't have a lock nut). It worked great and the throttle now stays at full throttle now. I can now see why you say to use the speed clips. Those little nuts were pretty tricky to get back on.
Thanks for the idea Geno!
05 Aug 2018 08:30 #14785 by Geno
You're most welcome Jimmy. Glad you got yours fixed. :thumb1
