Hein Werner A4CCWH
  • ManicMechanic
  • Junior Member
  • Junior Member
18 Jul 2016 10:37 #12064 by ManicMechanic
Hein Werner A4CCWH was created by ManicMechanic
Has anyone refilled one of these from a fresh rebuild and is it simple as removing the set screw and pouring the fluid in? I see many people have been using the Napa ATV which covers Dexron all the way up to V.
18 Jul 2016 16:41 #12066 by Geno
Replied by Geno on topic Hein Werner A4CCWH
On the 1054 tractors there's a plug on the backside toward the top where you fill it. Wheel Horse manuals say to be sure to leave it a little low for expansion.
  • ManicMechanic
  • Junior Member
  • Junior Member
18 Jul 2016 19:16 #12068 by ManicMechanic
Replied by ManicMechanic on topic Hein Werner A4CCWH
I found that the compression release is not functioning either? Could be water expansion in the oil, maybe change the oil and do a kerosene flush? I didn't pull the valve or cam covers off yet. Maybe when I tear down the carburetor I'll check the valve and cam, see if the spring is still good on the release? I know this fellow wants 550.00 for this machine with the deck, as it sits. I was thinking of taking it as a partial payment on a trade, but it is mechanically rough!
18 Jul 2016 21:03 #12071 by Geno
It's also one of the most rare Horses out there, they only made them 3 months. If it has the correct motor (K241AS-46219A) I would pay that for it in a minute. :)
  • ManicMechanic
  • Junior Member
  • Junior Member
19 Jul 2016 10:09 #12081 by ManicMechanic
Is it possible that the compression release is failing? Maybe I should pull it off the oil pan and have a look before I attempt to run it? I will do a kerosene flush next and drain into a separate can, look for any metal, etc. I'll double check the engine specs as well an see if it is original, I thought it was.
  • ManicMechanic
  • Junior Member
  • Junior Member
19 Jul 2016 11:39 #12082 by ManicMechanic
I checked my two k 241s the 1045 is original 46219A
the other is a 46215A and I can rotate that one with my hand on the shaft, no problem.
Still believe we have a release issue. The Tractor will go into storage until the off season, then I can consult with my Mechanic prior to getting too technically involved. It's a rare jewel so no Micky Rigging! Lol Clean out the engine and lube the hydro, then stow it.
19 Jul 2016 13:14 #12083 by Geno
Sounds like a plan. :thumb1
  • ManicMechanic
  • Junior Member
  • Junior Member
20 Jul 2016 09:10 - 20 Jul 2016 09:24 #12092 by ManicMechanic
I couldn't help myself! I removed the cam cover and examined the cam, it is an Automatic Spark Advance, not ACR. So the Generator Starter should be Heavy Duty?
Last edit: 20 Jul 2016 09:24 by ManicMechanic.
20 Jul 2016 17:44 #12095 by Geno
The Delco starter \ generator was plenty for that little engine. It's the same one that GM ran on all their cars back in the day.
  • ManicMechanic
  • Junior Member
  • Junior Member
24 Jul 2016 19:38 - 24 Jul 2016 19:47 #12123 by ManicMechanic
I found this interesting PDF, filled the Unit with Wheel Horse 4822, made a 3/8ths pulley for the Drill in Reverse, and Viola! Worked wonderfully!
Last edit: 24 Jul 2016 19:47 by ManicMechanic.
