Removing exhaust pipe
13 Apr 2015 19:28 #3189 by Geno
Removing exhaust pipe was created by Geno
Looking to see what works best for getting these pipes out of the engine blocks. What has worked best for you guys? :idea
I asked Sandra if she wanted a stack, she said "well duh". :rolling
Here's what we're working on -
13 Apr 2015 19:41 #3190 by M Bailey
Replied by M Bailey on topic Removing exhaust pipe
Geno I've had good luck with an 18" Rigid pipe wrench. Easier to remove if the block is warmed up first and a little Kroil on the threads helps out too!
13 Apr 2015 20:20 - 13 Apr 2015 20:21 #3191 by Trouty56
Replied by Trouty56 on topic Removing exhaust pipe
OK...here is what I do....I cut the pipe off about 1/2 inch away form the block.....then take a sawzall and cut the pipe at two places longwise....not quite through but enough to weaken the pipe wall....then take a punch and hammer it towards the inside.....
Last edit: 13 Apr 2015 20:21 by Trouty56.
13 Apr 2015 20:25 - 13 Apr 2015 20:25 #3192 by Geno
Replied by Geno on topic Removing exhaust pipe
You ever try the big honkin pipe wrench Bob? :idea
Last edit: 13 Apr 2015 20:25 by Geno.
13 Apr 2015 20:33 #3194 by Trouty56
No....I was always afraid to break something......pipe is cheaper to me.....but give it try if you like....
13 Apr 2015 21:22 #3198 by JustinW.73
Replied by JustinW.73 on topic Removing exhaust pipe
What I do is dab a little oil here, some there, and break out the heavy artillery! www.menards.com/main/plumbing/plumbing-t...p-1339101-c-8615.htm
13 Apr 2015 22:55 #3202 by Sandra
Replied by Sandra on topic Removing exhaust pipe
Well duh. :smile2
13 Apr 2015 23:09 #3205 by Bobster
Replied by Bobster on topic Removing exhaust pipe
I soaked mine for about 4 days with PB Blaster. Used a sharp chisel to break it loose. Worked but I was sweating all the while.
14 Apr 2015 06:46 #3221 by GT 14
Replied by GT 14 on topic Removing exhaust pipe
Warm it up and use the big Honker! :cents1
14 Apr 2015 08:04 #3230 by Geno
I've been putting PB Blaster on it for about 5 days. I got out the 2' pipe wrench and took a hammer to the end of it and gave it some hammer action and she came out. I like hammer action better than constant pressure, seems to break less things overall, sort of like an impact. Thanks for all the advise guys. :thumb1
Now I'm off to start a stack thread to see what you all have done so Sandra can see them. :smile2
