RJ58 transmission
  • motor12
08 Jul 2015 10:27 #6619 by motor12
RJ58 transmission was created by motor12
My RJ58 has a noisy trans, guess I'll have to live with it. I rebuilt the trans put in all new bearings, bushings, seals and gaskets. I replaced the idler pulley with a new one and run a 85wt to120wt gear oil. All works fine, very smooth but noisy.
08 Jul 2015 11:45 #6625 by Geno
Replied by Geno on topic RJ58 transmission
I haven't been in one of those but it sounds like a shimming issue to me.
03 Aug 2015 17:23 #7454 by M Bailey
Replied by M Bailey on topic RJ58 transmission
Can't believe I missed this post Motor. My 3 piece 5010 also has gear noise which I attribute to the straight cut gears, just like most of the older transmissions (easier to manufacture). Actually I think the "whine" kind of :cool
  • FewMoreMiles
05 Aug 2015 23:11 #7521 by FewMoreMiles
Replied by FewMoreMiles on topic RJ58 transmission
Go figure, my '58 is a bit noisy as well, however the much less expensive ball of rust aka 1960 Suburban, is as quiet as a church mouse.
06 Aug 2015 08:02 #7527 by AJ WH Ranger
Replied by AJ WH Ranger on topic RJ58 transmission
FewMoreMiles wrote: Go figure, my '58 is a bit noisy as well, however the much less expensive ball of rust aka 1960 Suburban, is as quiet as a church mouse.
Interesting.... Same trans?
