Onan 9 Pin Engine Pigtail
05 Dec 2020 16:56 #16518 by Geno
Onan 9 Pin Engine Pigtail was created by Geno
This 9 Pin Molex Connector Pigtail fits the original Onan Engine connector in the Wheel Horse Tractors. It has been upgraded from the original to all automotive grade high temperature 14 gauge wire in every circuit. All parts and wire to make these are Made in USA. Every piece is fully interchangeable with the original connector so if you just need 1 side or a few terminals and wire here and there they will all work with the existing connector.
Both male and female sides come with this, they are only separated for the pic. There is 6" of lead wire on each side, entire assembly when plugged together is 14".
You will also see that one wire in the assy is black with a white stripe, all other wires are black. The one with the white stripe is just to help with alignment when plugging in and to make things easier when replacing it so you have a reference point to go by.
It's about time someone made this pigtail and it's only available at the Stables. :thumb1
It is here - Onan 9 Pin Pigtail
Time to create page: 0.081 seconds
