Wheel Horse 4365R Clutch Facing
07 Dec 2020 09:11 - 07 Dec 2020 09:15 #16520 by Geno
Wheel Horse 4365R Clutch Facing was created by Geno
I've been trying to get these in the store for awhile and finally got it done this morning. :thumb1
Wheel Horse 4365R replacement PTO Clutch facing. This is a replacement facing and is a glue on type, you can drill it for rivets if you prefer. This facing is and upgrade to the original and is a woven facing, woven facings are much stronger than regular molded facings which can stand much more RPM and heat, which translates to better life and performance. Woven friction materials are commonly used in OEM vehicle applications, as they offer a good combination of smooth engagement, wear resistance, and strength. These are also Made in USA.
These are the same as the original except a little smaller opening in the center, but there is still plenty of room for the retainers as you can see in the pics. There is a pic of one on a plate and a pic of a NOS part on top of this one for reference.
Mounting them is up to your preference. Many people use rivets, Loctite 380, epoxy, JB Weld, and other glues. You can do a search and see what works well for others as many methods do seem to work. We use and only reccomend an epoxy resin made by Redco Manufacturing who are the people who made the original Wheel Horse brake and clutch linings but it does not come in small quantities and is expensive.
They are here - 4365R Replacement Clutch Facing
Last edit: 07 Dec 2020 09:15 by Geno.
