06 Aug 2017 07:17 #13951 by GT 14
:bow1 Lookin real fine!!:bow2
  • 23 AUTOMATIC LSE
25 Aug 2017 17:37 #13977 by 23 AUTOMATIC LSE
Just picked up the parts from the chrome shop, will try to get some pictures uploaded later. The 2 discs for the turning brakes, the block-off plate and the 2 cups under the hydro control valves. Turned out very good.
  • 23 AUTOMATIC LSE
26 Aug 2017 12:18 - 26 Aug 2017 12:21 #13978 by 23 AUTOMATIC LSE
Here are some pics of the parts I had chromed. Block-off plate, cups under control valves and discs.
It is nigh unto impossible to get good pics of chrome parts with my cell phone cam.
Last edit: 26 Aug 2017 12:21 by 23 AUTOMATIC LSE.
27 Aug 2017 01:00 #13979 by nappypappy
23 AUTOMATIC LSE wrote: Here are some pics of the parts I had chromed. Block-off plate, cups under control valves and discs.
They look great and so very very nice too..................:woo :10 :bacon0
30 Aug 2017 07:49 #13983 by Geno
Looking good Mark. This tractor will really be a show piece. :thumb1
01 Sep 2017 07:02 #13988 by GT 14
More bling for the chrome pony, your are the Rembrandt of restoration.
  • 23 AUTOMATIC LSE
11 Nov 2017 17:07 #14108 by 23 AUTOMATIC LSE
Thanks gentlemen, I finally have the second pair of hubs removed from the axles. I took them over to my neighbors' who has a 12-ton press; however, it would not even budge them. So I then proceeded to take them to a repair shop that had a 200-ton press. Needless to say, they were out the next day, oh and no heat, just a bit of penetrating oil and a lot of squeaking, + $40.00 (he wanted $50.00). I didn't take any pics, maybe after I get the paint on. Not much of an update but I just wanted to add this.
12 Nov 2017 07:47 #14109 by Geno
Some of those axle hubs can be a real pain, glad you saved them. :thumb1
  • 23 AUTOMATIC LSE
16 Nov 2017 21:46 #14119 by 23 AUTOMATIC LSE
Just took two of the back tires/wheels to a couple of tire shops. One was mounted; but, the area where the valve stem hole was welded shut, was ground down a bit too far so it leaked. Having this dismounted so it can be rewelded. The other has a bit of bead damage and both shop workers advised get a new tire or use a tube. A Carlisle Trac-Cheif in a 27 x 8.5 - 15 (6 plies) doesn't come cheap. Hoping to have the wheel with the leak welded and the tires mounted this weekend.
  • 23 AUTOMATIC LSE
20 Nov 2017 13:18 - 20 Nov 2017 13:20 #14124 by 23 AUTOMATIC LSE
Just a bit of an update, took the tire with the damaged bead areas and the wheel to Best One Tire service center. They dismounted, cleaned and applied some bead sealer prior to remounting and inflating. Temporarily mounted hubs and tire/wheel assemblies to axles to get a couple pics. First is Dual hubs on axles the second one is all 4 temporarily mounted.
P.S. Right fender is slightly off level because I did not have the under fender support bolted on.
Last edit: 20 Nov 2017 13:20 by 23 AUTOMATIC LSE.
