Leak at the brake
13 Jun 2015 06:20 #5759 by nappypappy
Leak at the brake was created by nappypappy
Its had a leak for awhile now but I got looking at it yesterday and it seems to be coming from around the brake on this 8speed..
I did replace the brake on it several years ago....
So my question is what would cause it to leak?
Do need to take the tranny apart?
Worn out bushings bearings seals etc....:smile2
13 Jun 2015 06:58 #5760 by M Bailey
Replied by M Bailey on topic Leak at the brake
Pappy, unless the needle bearing is shot, the seal can be replaced without pulling the transmission. If there's side to side play in the brake shaft it'll need a new bearing. The TORO part number for the seal is 100441 or go to NAPA and get an SKF7410, 0.75" Shaft Diameter 0.999" Bore Diameter 0.125" Width.
13 Jun 2015 08:20 #5764 by nappypappy
Replied by nappypappy on topic Leak at the brake
M Bailey wrote: Pappy, unless the needle bearing is shot, the seal can be replaced without pulling the transmission. If there's side to side play in the brake shaft it'll need a new bearing. The TORO part number for the seal is 100441 or go to NAPA and get an SKF7410, 0.75" Shaft Diameter 0.999" Bore Diameter 0.125" Width.
Ok thanks.... I will have to a take a closer look at it.......and will report back after that.....
13 Jun 2015 08:56 #5767 by Geno
Replied by Geno on topic Leak at the brake
Could be a little rust down there from where its been sitting.
13 Jun 2015 18:03 #5788 by nappypappy
Geno wrote: Could be a little rust down there from where its been sitting.
Yeah could be haven't checked it out real good yet....kinda hot out there today.....oh I did order a tub from tractor supply.....trying not to get it dirty....
:smile2
09 Aug 2015 08:52 #7640 by nappypappy
well a little update and brake isn't leaking its coming from the center of the tranny where the two halves meet from up I can tell.....so do I need a gasket?
:smile2
09 Aug 2015 09:00 #7641 by Geno
There's a drain plug under there, is it coming from that?
09 Aug 2015 09:12 #7642 by nappypappy
Geno wrote: There's a drain plug under there, is it coming from that?
Not sure since I couldn't get it to turn either way...going to run it some more later to be sure where its leaking but I do no its not at the brake.....my have to pull it out and take a closer look.....oh if I only had a forklift......like somebody I know......:smile2
22 Aug 2015 09:04 - 22 Aug 2015 20:47 #7948 by nappypappy
well its leaking at the brake for sure.....looks like I will have to take it apart.........are there many gaskets that I need to order?
Has anybody else had to take a 8 apart and what gaskets did you replace?
Or should I wait till I open it to order anything?
Anybody have any pictures?
:smile2
Last edit: 22 Aug 2015 20:47 by nappypappy.
23 Aug 2015 07:07 - 23 Aug 2015 07:08 #7949 by nappypappy
Well I don't see a seal on this....is that possible or is it really small..:smile2
Last edit: 23 Aug 2015 07:08 by nappypappy.
