Project Clydesdale
15 Dec 2018 10:19 - 08 Feb 2019 16:41 #15038 by Geno
I really shouldn't be wasting time with this but it is so much fun, and I need some fun lol... :tounge2
Last edit: 08 Feb 2019 16:41 by Geno.
15 Dec 2018 10:42 #15039 by whnewone
1984 C-145
1983 C-145
1983 GT1848
1994 416-8
15 Dec 2018 11:44 - 15 Dec 2018 11:46 #15040 by Geno
Thanks Bill. :thanks
Here is some of the progression from yesterday and this morning. Frame is stripped down minus the rear pegs that I may use. The front steering bracket that was removed was cut down and moved to the rear. The steering fan was removed, it needs to be flipped the other direction. I also made a few 1/4" steel brackets to hold some things... :yes
I should have the frame portion of the steering done by lunch today. :thumb1
Last edit: 15 Dec 2018 11:46 by Geno.
15 Dec 2018 14:24 #15041 by Geno
15 Dec 2018 18:35 #15042 by Geno
Frame is blasted + painted. :woo
17 Dec 2018 19:34 #15046 by Geno
Got most of the joint done, just needs cleanup, blasting + paint. :woo
18 Dec 2018 16:48 #15047 by Geno
18 Dec 2018 20:15 #15048 by Geno
Here is the powertrain. :thumb1
19 Dec 2018 11:34 #15052 by nappypappy
that will be something to see when its done..yeah...................................................................................................:10 :smile2 :bacon0
19 Dec 2018 12:41 #15056 by Geno
It should be pretty cool, but it will be pretty time consuming as well... :thumb1
I am proud of my mount, as simple as it gets and does all directions. :thumb
Time to create page: 0.182 seconds
