Project Clydesdale
28 Jan 2019 19:02 #15174 by Bert
Replied by Bert on topic Project Clydesdale
That’s a pretty neat build, looking forward to seeing it finished :woo
28 Jan 2019 20:11 #15175 by Geno
Thanks and good to see you Bert. :thumb1
28 Jan 2019 20:16 - 28 Jan 2019 20:17 #15176 by Geno
nappypappy wrote: I still thing you may need a transfer case or maybe a bigger motor like what GT has on his wheelhorse...........:smile2 :2cents :cof3 :bday5 :computer :bacon0
I'm on to a 25HP Kohler Command, just need to get outta here to pick it up. :thumb
Last edit: 28 Jan 2019 20:17 by Geno.
28 Jan 2019 20:46 #15177 by Bert
Geno wrote: Thanks and good to see you Bert. :thumb1
Thanks, it’s good to be back.
30 Jan 2019 18:09 #15179 by Geno
Most of the front brake set up is done. The factory lock system is blasted, painted and in the tractor. I took the rear bracket that was welded on the back of the factory rod off and it will be welded where the vise grips are holding it, then I need to make an extension for the original rod to my new rod so they can link together. The spring is temporary to hold it in the first brake lock notch, the entire travel will only be about 1/2" from released to locked so I want to make sure it's in the lock area. It still has the bottom spring setup off of the original setup so there will be some adjustment. :thumb
31 Jan 2019 17:44 #15180 by Geno
A lot going on today but I did manage to finish the front braking setup. Everything from the pedal to the lock setup is original minus the extra rod tab, and the adjustment is original just flipped so it gets pushed on instead of pulled on. It works really well, I just had to rebend the rod a little from yesterday. :woo
01 Feb 2019 18:20 #15181 by Geno
The fender is on and notched for the new brake setup. It's not the prettiest but that will be fixed after it's plated lol. I made a new bracket to hold 2 fuse blocks and moved them up a little above the battery top so they're easier to get to. Now to figure out what is next...
02 Feb 2019 12:13 #15186 by GT 14
That brake rod is not coming off that's for sure. :bow2
05 Feb 2019 21:29 #15191 by Geno
I hope not, like Nappy says, safety first lol. :smile2
06 Feb 2019 18:37 #15196 by Geno
Good news is I got out for pizza and to pick up my engine today. It's a Kohler command Pro 25HP. :woo
Bad news is it is in pieces lol. :rolling The rings were stuck in it from sitting but everything else looks good minus a good cleaning, rings, gaskets, and reassembly.
